1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: bug in Red Hat Linux g++ 3.2.3
To: "'EPICS Tech Talk'" <[email protected]>
Date: Wed, 22 Aug 2007 10:35:53 -0600
All,
There is a bug in Red Hat Linux g++ 3.2.3 when -O3 is specified that causes CA R3.14.9 to fail. The bug is known not to occur with several other g++ versions, but many versions have not been tested. I also don’t know what versions of Linux g++ are most commonly used at the various EPICS sites.
So I am curious if this is a substantial issue for the EPICS community or if it can be safely ignored? If defective compilers are still in widespread use I could look for a workaround in the EPICS source code.
Jeff
During testing of R3.14.9 I see a bug showing up only in optimized builds on Linux using g++ 3.2.3 that I don't see with other compilers. This bug appears to be related to failure of this particular compiler to follow the strict alias rules specified in the standard when optimizing the byte swapping templates installed for R3.14.9.
Problems
Red hat Linux g++ 3.2.3 when -O3 is specified
No problems
mingw g++ 3.4.2 -O3
Tornado 2.02 g++ -O2
Microsoft C++ 2005 full optimization builds
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
Prev: asyn 4.8 problem Robert Emery
Next: RE: asyn 4.8 problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn 4.8 problem Robert Emery
Next: Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
