Hi
The bug also occurs with -O2, only -O1 is safe.
gcc 3.2.3 is the standard version on Scientific Linux 3, which we still
have in use at the SLS. I would very much appreciate a workaround in the
EPICS code.
Dirk
Jeff Hill wrote:
All,
There is a bug in Red Hat Linux g++ 3.2.3 when -O3 is specified that
causes CA R3.14.9 to fail. The bug is known not to occur with several
other g++ versions, but many versions have not been tested. I also don’t
know what versions of Linux g++ are most commonly used at the various
EPICS sites.
So I am curious if this is a substantial issue for the EPICS community
or if it can be safely ignored? If defective compilers are still in
widespread use I could look for a workaround in the EPICS source code.
Jeff
During testing of R3.14.9 I see a bug showing up only in optimized
builds on Linux using g++ 3.2.3 that I don't see with other compilers.
This bug appears to be related to failure of this particular compiler to
follow the strict alias rules specified in the standard when optimizing
the byte swapping templates installed for R3.14.9.
*Problems*
Red hat Linux g++ 3.2.3 when -O3 is specified
*No problems*
mingw g++ 3.4.2 -O3
Tornado 2.02 g++ -O2
Microsoft C++ 2005 full optimization builds
______________________________________________________
Jeffrey O. Hill Internet [email protected]
<mailto:[email protected]>
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- RE: bug in Red Hat Linux g++ 3.2.3 Jeff Hill
- bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Re: StreamDevice protocol question Dirk Zimoch
Re: Network plug and play epics devices Dirk Zimoch
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
