1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Network plug and play epics devices
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Mon, 27 Aug 2007 11:08:11 +0200
Hi Emmanuel,
have you successfully run EPICS on a picotux?
I tried it some months ago but failed. It seems the toolchain does not generate the necessary code the run the constructors of global C++ objects. The effect was that all the registrars did not work and the only available command in iocsh was "exit".
Dirk
Emmanuel Mayssat wrote:
A chiller usually comes with a serial or Ethernet interface. A computer
is not included (contrary to detectors;). So you add one (let's call it
a picotux computer http://en.wikipedia.org/wiki/Picotux or a gumstix).
You install epics and chiller driver on computer stick. As you do so
your chiller has just become "plug-and-play".
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: Network plug and play epics devices Mark Rivers
RE: Network plug and play epics devices Emmanuel Mayssat
Prev: Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
Next: ASYN & ioclog/CMLOG Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Network plug and play epics devices Mark Rivers
Next: RE: Network plug and play epics devices David DeBonis
