1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn 4.8 problem
To: "Robert Emery" <[email protected]>
Cc: [email protected]
Date: Thu, 23 Aug 2007 11:43:09 -0500
Hi Robert,
> When I tried using asynSetTraceMask with my ioc that was
> working using asyn 4.5, the ports that I set asynTraceMask
> for would no longer connect.
That is very interesting.  When you set asynTraceMask that actually
results in a call to pasynCommon->connect.  That happens at the time of
the call to asynSetTraceMask.  So it is should be connecting to the
device at that point.
But then you have this line:
## Reboot the GPIB gateway
E5810Reboot("192.168.0.63",0)
I am not familiar with the VXI-11 and GPIB gateway, but is it possible
that rebooting the gateway is breaking the connection that has already
been made because you set the asynTraceMask?
Here are 3 suggestions:
- Remove the call to E5810Reboot temporarily to see if that fixes the
problem.
- Move the call to asynSetTraceMask to after the E5810Reboot call
- Put a delay (epicsThreadSleep) after the E5810Reboot to see if the
device is simply not quite ready yet to accept connections when iocInit
is run.
> -----Original Message-----
> From: Robert Emery [mailto:[email protected]]
> Sent: Thursday, August 23, 2007 11:02 AM
> To: Mark Rivers
> Subject: Re: asyn 4.8 problem
> Mark,
> I made the changes to asynManager but that made no
> difference.  I tried
> using the asynSetTraceMask but that did not give me any more
> information.  When I tried using asynSetTraceMask with my ioc
> that was
> for would no
> longer connect.
> I have attached the outputs from various ioc configurations.
> Thanks
> Rob
> Mark Rivers wrote:
> > Rob,
> > We recently had a report from Dirk Zimich at PSI that VXI11 was not
> > working with asyn R4-8.  But he was upgrading from EPICS
> R3.13, not an
> > earlier version of asyn.  So your report is very useful,
> since you say
> > it worked in asyn R4-5.
> > Can you send the complete output when your IOC starts?
> > Can you set the asynTraceMask on that asyn port so that you get full
> > debugging information?
> > Also, I suspect that the problem may be coming from the
> code that was
> > added in asyn R4-6 to automatically queue a connect request (call to
> > pasynCommon->connect) when a call to
> pasynManager->connectDevice is done
> > for a port with the attributes autoConnect=Yes and isConnected=No.
> > Can you please try disabling this code with the following
> change that
> > comments out the call to pasynCommon->connect() and letting
> me know if
> > it fixes the problem?
> > corvette> cvs diff -rR4-8 asynManager.c
> > Index: asynManager.c
> > RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/asy
> nDriver/as
> > ynManager.c,v
> > retrieving revision 1.93
> > diff -u -r1.93 asynManager.c
> > --- asynManager.c       28 Apr 2007 21:19:58 -0000      1.93
> > +++ asynManager.c       22 Aug 2007 17:25:32 -0000
> > @@ -1185,6 +1185,7 @@
> >      pasynCommon = (asynCommon *)pasynInterface->pinterface;
> >      commonPvt   = pasynInterface->drvPvt;
> >      status = pasynCommon->connect(commonPvt, pasynUser);
> >      if (status != asynSuccess) {
> >          asynPrint(pasynUser, ASYN_TRACE_ERROR,
> > @@ -1192,6 +1193,7 @@
> >                    portName, pasynUser->errorMessage);
> >          goto cleanup;
> >      cleanup:
> >      status = pasynManager->freeAsynUser(pasynUser);
> > Thanks,
> > Mark
> >> From: [email protected]
> >> [mailto:[email protected]] On Behalf Of Robert Emery
> >> Sent: Wednesday, August 22, 2007 11:25 AM
> >> To: [email protected]
> >> Subject: asyn 4.8 problem
> >> I have recently upgraded from asyn 4.5 to 4.8 and am seeing the
> >> following error messages whereas I didn't have them with 4.5:
> >> Starting iocInit
> >> ###  EPICS IOC CORE built on Oct  9 2006
> >> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> >> 2007/08/22 09:01:13.319 gpib0,1 vxiCreateDeviceLink RPC
> error : RPC:
> >> Unable to receive; errno = Connection reset by peer
> >> 2007/08/22 09:01:13.319 CoilA vxiCreateDevLink failed for addr 1
> >> 2007/08/22 09:01:13.319 asynManager::asynConnectCallback,
> port CoilA
> >> error calling asynCommon->connect
> error : RPC:
> >> Unable to send; errno = Broken pipe
> >> I am using this to control equipment on GPIB via an Agilent E5810
> >> Ethernet/GPIB bridge.
> >> Any ideas?
> >> Thanks
> >> Rob Emery
> >> UW Medical Center
Re: asyn 4.8 problem Robert Emery
Prev: Re: ethernet IP John Sinclair
Next: Re: StreamDevice protocol question Rodney R. Porter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn 4.8 problem Matthew Pearson
Next: Re: asyn 4.8 problem Robert Emery
