1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn 4.8 problem
To: Robert Emery <[email protected]>
Cc: [email protected]
Date: Thu, 23 Aug 2007 17:30:26 +0100
We've been using VXI11 over Asyn 4-8, talking to a Agilent E5810A, for a while now. However, I never did get this to work on VxWorks. Using Linux is fine (RedHat Enterprise 4, 2.6.9-42.0.3.ELsmp).
When I did try to use VXI11 on VxWorks I got a different error to what you saw, which I posted to tech-talk on 15th June 07.
Cheers,
Mathew
Diamond Light Source
On Thu, 2007-08-23 at 09:01 -0700, Robert Emery wrote:
Mark,
I made the changes to asynManager but that made no difference.  I tried
using the asynSetTraceMask but that did not give me any more
information.  When I tried using asynSetTraceMask with my ioc that was
working using asyn 4.5, the ports that I set asynTraceMask for would no
longer connect.
I have attached the outputs from various ioc configurations.
Thanks
Rob
Mark Rivers wrote:
> Rob,
> We recently had a report from Dirk Zimich at PSI that VXI11 was not
> working with asyn R4-8.  But he was upgrading from EPICS R3.13, not an
> earlier version of asyn.  So your report is very useful, since you say
> it worked in asyn R4-5.
> Can you send the complete output when your IOC starts?
> Can you set the asynTraceMask on that asyn port so that you get full
> debugging information?
> Also, I suspect that the problem may be coming from the code that was
> added in asyn R4-6 to automatically queue a connect request (call to
> pasynCommon->connect) when a call to pasynManager->connectDevice is done
> for a port with the attributes autoConnect=Yes and isConnected=No.
> Can you please try disabling this code with the following change that
> comments out the call to pasynCommon->connect() and letting me know if
> it fixes the problem?
> corvette> cvs diff -rR4-8 asynManager.c
> Index: asynManager.c
> RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/asynDriver/as
> ynManager.c,v
> retrieving revision 1.93
> diff -u -r1.93 asynManager.c
> --- asynManager.c       28 Apr 2007 21:19:58 -0000      1.93
> +++ asynManager.c       22 Aug 2007 17:25:32 -0000
> @@ -1185,6 +1185,7 @@
>      pasynCommon = (asynCommon *)pasynInterface->pinterface;
>      commonPvt   = pasynInterface->drvPvt;
>      status = pasynCommon->connect(commonPvt, pasynUser);
>      if (status != asynSuccess) {
>          asynPrint(pasynUser, ASYN_TRACE_ERROR,
> @@ -1192,6 +1193,7 @@
>                    portName, pasynUser->errorMessage);
>          goto cleanup;
>      cleanup:
>      status = pasynManager->freeAsynUser(pasynUser);
> Thanks,
> Mark
>> -----Original Message-----
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of Robert Emery
>> Sent: Wednesday, August 22, 2007 11:25 AM
>> To: [email protected]
>> Subject: asyn 4.8 problem
>> I have recently upgraded from asyn 4.5 to 4.8 and am seeing the
>> following error messages whereas I didn't have them with 4.5:
>> Starting iocInit
>> ###  EPICS IOC CORE built on Oct  9 2006
>> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
>> 2007/08/22 09:01:13.319 gpib0,1 vxiCreateDeviceLink RPC error : RPC:
>> Unable to receive; errno = Connection reset by peer
>> 2007/08/22 09:01:13.319 CoilA vxiCreateDevLink failed for addr 1
>> 2007/08/22 09:01:13.319 asynManager::asynConnectCallback, port CoilA
>> error calling asynCommon->connect
>> Unable to send; errno = Broken pipe
>> I am using this to control equipment on GPIB via an Agilent E5810
>> Ethernet/GPIB bridge.
>> Any ideas?
>> Thanks
>> Rob Emery
>> UW Medical Center
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0D! E, United Kingdom
RE: asyn 4.8 problem Mark Rivers
Re: asyn 4.8 problem Robert Emery
Prev: Re: asyn 4.8 problem Robert Emery
Next: Re: ethernet IP John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: asyn 4.8 problem Mark Rivers
