1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gateway problem
To: [email protected]
Date: Tue, 28 Aug 2007 19:34:43 +0900
Hi
I am trying to use gateway, and I have encountered with a problem.
The problem appeares when writing array data through gateway using "caput -a" command.
(Gateway2.0.2.1 built with Base3.14.9 on Scientific Linux 4.2)
Writing a scalar data through gateway, it will successfully completed.
Writing array data without gateway, it will successfully completed.
Environment variable EPICS_CA_MAX_ARRAY_BYTES is correctly set, of course.
Has anyone else encountered with this problem?
Yuichi ITOH
Re: gateway problem Ralph Lange
Prev: Re: Soft IOC for A GPIB Instrument Emmanuel Mayssat
Next: comedi :) Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Soft IOC for A GPIB Instrument Peter Mueller
Next: Re: gateway problem Ralph Lange
