Hello Yuichi,
could you be a bit more specific about the nature of the problem you are
experiencing?
Ralph
Yuichi ITOH wrote:
Hi
I am trying to use gateway, and I have encountered with a problem.
The problem appeares when writing array data through gateway using "caput -a" command.
(Gateway2.0.2.1 built with Base3.14.9 on Scientific Linux 4.2)
Writing a scalar data through gateway, it will successfully completed.
Writing array data without gateway, it will successfully completed.
Environment variable EPICS_CA_MAX_ARRAY_BYTES is correctly set, of course.
Has anyone else encountered with this problem?
Yuichi ITOH
- Re: gateway problem Gasper Jansa
- Re: gateway problem Noboru Yamamoto
- gateway problem Yuichi ITOH
Channel Archiver make problem Umashankar Panda
about building linux-gpib zhangdemin99
<2007>
2025
2026
<2007>
2025
2026
