1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway problem
To: "Ralph Lange"<[email protected]>, "Yuichi ITOH"<[email protected]>
Date: Thu, 30 Aug 2007 02:32:18 +0900 (JST)
Hi Ralph,
I'm not sure if it is same phenomena Yuichi has, but here is
I confirmed tonight.
My Environment:
EPICS 3.14.9
gateway 2_0_2_1 ( and 2_0_0_0)
MacOSX 10.4.10 running on IntelMac.
Symptom:
for a waveform record with FTVL=DOUBLE in iocsh.
a) "caput -a" through DIRECT CA access to IOCSH works OK.
b) Python CA( which uses native DBR type ) works OK for both direct
and through-a-gateway access to this record.
c) "caput -a" through a gateway fail.
d) "caput -a -c" through a gateway also fail with "write callback timeout".
IF I changed FTVL of this record to STRING.
All methods, a)-d), works OK.
So, this is consistent with the report from Gasper.
I also read the source code of caput, and found it send data as STRING
for "caput -a".
This is almost all I know about this issue.
best regards,
Noboru
--- "Ralph Lange" <[email protected]> ---
>Hello Yuichi,
>could you be a bit more specific about the nature of the problem you are
>experiencing?
>Regards,
>Ralph
>Yuichi ITOH wrote:
>> Hi
>> I am trying to use gateway, and I have encountered with a problem.
>> The problem appeares when writing array data through gateway using "caput -a" command.
>> (Gateway2.0.2.1 built with Base3.14.9 on Scientific Linux 4.2)
>> Writing a scalar data through gateway, it will successfully completed.
>> Writing array data without gateway, it will successfully completed.
>> Environment variable EPICS_CA_MAX_ARRAY_BYTES is correctly set, of course.
>> Has anyone else encountered with this problem?
>> Thanks,
>> Yuichi ITOH
gateway problem Yuichi ITOH
Re: gateway problem Ralph Lange
Prev: Re: Heidenhain Absolute Multiturn Rotary Encoder Pete Jemian
Next: RE: gateway problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: gateway problem Jeff Hill
Next: comedi :) Heinrich du Toit
