1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-star 300 --
To: [email protected]
Date: Wed, 29 Aug 2007 11:20:45 +0200
Hi
Thanks Ron and kurt
We try to move manually a motor : The encoder counts (.REP field) go up and down accordingly.
We have already test "UN" or "BI" in ASCII command but we not seen a difference.
if we try "HN" command we can see on scope that VME58 board send negative and positive signal and its oscillate motor move offcourse in both direction. this proove that oms board can produce a negative voltage ( it's not a hardware or connectic problem) but unfortunatly if we send a MR command in both direction the voltage continu to be only positive and the motor in only one direction.
It's crazy
thanks for any ideas for check
begin:vcard
fn:Jerome HOSSELET
n:HOSSELET;Jerome
org:CNRS / IPHC;Electronique / Informatique
adr:;;23 rue du loess;Strasbourg;;67000;FRANCE
email;internet:[email protected]
title:Assistant Ingenieur
tel;work:03 88 10 65 30
tel;home:03 88 xx xx xx
tel;cell:06 60 xx xx xx
note;quoted-printable:Assistant Ing=C3=A9nieur =C3=A0 l' IPHC :=0D=0A=
	- Projet CMS=0D=0A=
	- Projet SPIRAL 2
x-mozilla-html:FALSE
url:http://ireswww.in2p3.fr/
version:2.1
end:vcard
Prev: Re: Soft IOC for A GPIB Instrument Peter Mueller
Next: Channel Archiver make problem Umashankar Panda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- Ron Sluiter
