1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS device support questions
To: [email protected]
Cc: [email protected]
Date: Tue, 04 Sep 2007 16:49:10 -0700
Although the concept of directly calling API functions from EPICS sounds very clean I know of no way of handling the parameterization properly. Two approaches I might use are:
1. Use subroutine (ie, "sub") or genSub records. In this case you would have to write a C function that maps the API function parameters into the subroutine record parameter fields and reads or writes those fields as appropriate when the record processes. This way you could still reasonably approximate the API functional layout.
2. Write custom device supports for whatever record types seem appropriate, using the API at the next level down, corresponding to driver support. In the case of complex devices this leads to a suite of device supports. In the case of an oscilloscope, I would use ao records for many of the controls, waveform records for reading the traces, mbbo for selecting triggering modes, and so forth. This method can achieve a high level of integration between device and EPICS functionalities.
Carl
Gabriel L. Rael wrote:
Hello, all.
We are in the process of creating an EPICS interface to our oscilloscope. It is a PCI device with its own kernel driver and user space driver with the host processor that will be running our EPICS IOC.
It seems that though EPICS supports a list of communication interfaces (GPIB, VME, VXI, serial, etc.), it does not allow for a device to be connected above this layer through an ANSI-C API easily. Though asyn device support is a complete solution down to the kernel level, we want to be able to leverage our existing drivers.
For packaging up this functionality, we want to create records that map directly to our API calls, which are functions with variable arguments, some that may be passed by reference for modification. We have function tables containing our calls with variable argument types, but we are not seeing a common way to link PVs to function calls with arguments. In the dbd, we are doing something like: device(ao, INST_IO, devScopeao, "scopeAPI"). Can I use the INP and OUT fields arbitrarily, parsing a common syntax (i.e. a single string value such as "@function arg1 arg2") in the device support layer, to make function wrappers? Is there a general way that we can hook into something that already accomplishes this? Does this break the ability to link PVs properly? Can I do this using the standard record types? Am I missing something else?
Thanks in advance!
-glr
Carl Lionberger 510 486 7503
Software Developer, Engineering Division
Lawrence Berkeley National Laboratory
EPICS device support questions Gabriel L. Rael
Prev: Re: EPICS device support questions Eric Norum
Next: RE: EPICS device support questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS device support questions Jeff Hill
Next: EPICS Python?? Heinrich du Toit
