1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS device support questions
To: "Chestnut, Ronald P." <[email protected]>
Cc: [email protected]
Date: Tue, 4 Sep 2007 18:44:51 -0500
On Sep 4, 2007, at 6:26 PM, Chestnut, Ronald P. wrote:
Dear Gabriel,
You are asking about doing this in a very clean way, which one can only strongly encourage.
We have done some interfacing to high-speed RF Analog and Digital equipment using a USB interface. The FPGA in the equipment uses a set of registers to communicate, and on the EPICS side, we use a set of canned USB-calling subroutines. The division of labor lets non-EPICS engineers get the Linux and FPGA sides of the USB calls working, then we use subroutine records in EPICS to call the engineer-certified routines.
One interesting feature needed for work with EPICS was some semaphores to keep the USB calls single-threaded, since the FPGA side can deal with only one request at a time.
At this point I'd like to put in my obligatory plug for ASYN which does the locking and multi-threading for you. ASYN also provides mechanisms for producing diagnostic/debugging messages along with records and MEDM screens for controlling them. This unified method of producing and controlling driver trace/debug/diagnostic messages makes ASYN useful for synchronous register-based devices as well as asynchronous message-based devices. ASYN can also decouple drivers from records so the same support can be used with different record types.
Maybe Marty Kraimer, Mark Rivers or others can add their own testimonials here for why ASYN is a good framework for writing drivers.....
This is not as pure or clean as a good device-oriented implementation, but it does work - we have three different devices in service this way.
Ron Chestnut
-----Original Message-----
From: [email protected] [mailto:tech-talk- [email protected]] On Behalf Of Gabriel L. Rael
Sent: Tuesday, September 04, 2007 3:59 PM
To: [email protected]
Subject: EPICS device support questions
Hello, all.
We are in the process of creating an EPICS interface to our oscilloscope. It is a PCI device with its own kernel driver and user space driver with the host processor that will be running our EPICS IOC.
It seems that though EPICS supports a list of communication interfaces (GPIB, VME, VXI, serial, etc.), it does not allow for a device to be connected above this layer through an ANSI-C API easily. Though asyn device support is a complete solution down to the kernel level, we want to be able to leverage our existing drivers.
For packaging up this functionality, we want to create records that map directly to our API calls, which are functions with variable arguments, some that may be passed by reference for modification. We have function tables containing our calls with variable argument types, but we are not seeing a common way to link PVs to function calls with arguments. In the dbd, we are doing something like: device(ao, INST_IO, devScopeao, "scopeAPI"). Can I use the INP and OUT fields arbitrarily, parsing a common syntax (i.e. a single string value such as "@function arg1 arg2") in the device support layer, to make function wrappers? Is there a general way that we can hook into something that already accomplishes this? Does this break the ability to link PVs properly? Can I do this using the standard record types? Am I missing something else?
Thanks in advance!
-glr
Gabriel L. Rael
Jr. Software Engineer
ZTEC Instruments
http://www.ztecinstruments.com
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
RE: EPICS device support questions Mark Rivers
EPICS device support questions Gabriel L. Rael
RE: EPICS device support questions Chestnut, Ronald P.
Prev: RE: EPICS device support questions Jeff Hill
Next: Re: EPICS device support questions Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS device support questions Chestnut, Ronald P.
Next: RE: EPICS device support questions Mark Rivers
