1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Extensions
To: "EPICS tech-talk" <[email protected]>
Date: Wed, 5 Sep 2007 12:41:41 -0700
Now since I have my first softIOC working, I thought I add some extensions to my EPICS 3.14.9 installation.  First I tried the Extension Top (new method), which I installed in epics/R3.14.9/extensions, where epics/R3.14.9/base was already configured and installed.  I examined CONFIG, CONFIG_SITE, and RELEASE files in extensions/configure and ran make in extensions/configure according to the instructions in README without errors.  Then I unpacked medm3_1_1.tar.gz into epics/R3.14.9/ and the files got copied into extensions/src as expected.  To build medm I
cd extensions/src/medm
make
And this is what I got:
zms@esaux1 $ make
Makefile:20: ../../../config/CONFIG_EXTENSIONS: No such file or directory
Makefile:22: ../../../config/RULES_DIRS: No such file or directory
gmake: *** No rule to make target `../../../config/RULES_DIRS'.  Stop.
zms@esaux1 $ pwd
/afs/slac.stanford.edu/g/esa/esalib/app1/epics/R3.14.9/extensions/src/medm
It seems that it expects config directory in epics/R3.14.9.  The only config directory is in epics/R3.14.9/base.  Is that the one it expected to find?  Or should there be one in extensions?  Furthermore nowhere could I find CONFIG_EXTENSIONS.  I see such a file exists in older versions of epics, specifically in 3.14.6.  Am I reading the README file incorrectly and consequently skipping some important step?  How could I go around this difficulty to be able to build medm (and other extensions as well.  I also tried probe with the same results)?  I could create a link in extensions to epics/R3.14.9/base/config and copy CONFIG_EXTENSIONS from another version of epics.  Is this safe do?
I also tried Configure Files (Old method) with similar unsatisfactory results.  Please, advise.
Zen
Re: EPICS Extensions Andrew Johnson
Prev: RE: ASYN & ioclog/CMLOG Mark Rivers
Next: Re: EPICS Extensions Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: cmlog compile problems Heinrich du Toit
