1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Extensions
To: "Andrew Johnson" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 5 Sep 2007 13:25:18 -0700
Thanks.  Another small problem.  Medm expects /usr/lib/libXm.a which on my computer is at /usr/X11R6/lib/libXm.a.  What is the best was to specify where the library is located?
Zen
-----Original Message-----
Sent: Wednesday, September 05, 2007 12:52 PM
To: Szalata, Zenon M.
Cc: EPICS tech-talk
Subject: Re: EPICS Extensions
Szalata, Zenon M. wrote:
> I also tried Configure Files (Old method) with similar unsatisfactory
> results.  Please, advise.
You need MEDM version 3.1.2.1 to use the R3.14 build files; MEDM 3.1.1 needs the old extensionsConfig area instead; I would definitely recommend getting the newer version of MEDM rather than trying to set up the older extensions area.
- Andrew
When a distinguished but elderly scientist states that something is possible, he is almost certainly right.  When he states that something is impossible, he is very probably wrong.  -- Arthur C. Clarke
Re: EPICS Extensions Bob Soliday
EPICS Extensions Szalata, Zenon M.
Re: EPICS Extensions Andrew Johnson
Prev: Re: EPICS Extensions Andrew Johnson
Next: Re: EPICS Extensions Bob Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
