1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: edm
To: "EPICS tech-talk" <[email protected]>
Date: Wed, 5 Sep 2007 15:44:44 -0700
Installed and build edm without problems.  Now I am following edm installation example from "How-To's and Examples" and am having difficulty with the Configure part.  Here is what is in the example file:
 Configure
  1) create project directories
       cd /home/user
       mkdir edm
       mkdir edm/prefs
  2) set environment variables
       export EDMOBJECTS=/home/user/edm/prefs
       export EDMDATAFILES=/home/user/edm
       export EDMFILES=/home/user/edm/prefs
       export EDMPVOBJECTS=/home/user/edm/prefs
       export EDMHELPFILES=/epics/supTop/extensions/src/edm/helpFiles
       The above variables should be set in /home/user/.bashrc
  3) create and populate component files
       edm -addPv /epics/supTop/extensions/lib/linux-x86/libEpics.so
       edm -add /epics/supTop/extensions/lib/linux-x86/libEdmBase.so
       edm -add /epics/supTop/extensions/lib/linux-x86/...
                ...libcfcaa62e-8199-11d3-a77f-00104b8742df.so
                ...libcf322683-513e-4570-a44b-7cdd7cae0de5.so
                ...lib7e1b4e6f-239d-4650-95e6-a040d41ba633.so
                ...lib57d79238-2924-420b-ba67-dfbecdf03fcd.so
Step 1 and 2 no problem.  Step 3, problems:
zms@esaux1 $ edm -addPv /afs/slac/g/esa/esalib/app1/epics/R3.14.9/
Cannot open pv objects file - /u/ra/zms/esa/edm/prefs/edmPvObjects
Unknown command line parameter (-h displays help)
The next command succeeds and creates edmObjects in edm/prefs, but the remaining commands seem to need the edmPvObjects and hence fail.
Are the steps outlined in the installation example outdated or something?
How should I setup my project area?  Thanks for helping.
Zen
Re: edm John Sinclair
Prev: Re: EPICS Extensions Bob Soliday
Next: Re: EPICS Python?? Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: edm John Sinclair
