1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epics vxworks time off by 1 hour
To: [email protected]
Date: Fri, 07 Sep 2007 16:02:25 -0500
The time that epics records for updates of my PVs in some vxworks nodes
is off by one hour. This is the time seen by camonitor, the channel archiver, etc.
If I run the vxworks time() function which gives me seconds since 1970, the value returned
matches that returned by unix's time() (/usr/include/time.h) on my unix nodes.
I run date() on  vxworks, I also get the correct date and time printed out.
This date() is apparently provided by EPICS since
   lkup "date"
finds it in my EPICS object .munch file.
so the system knows the proper date and time.
But somehow EPICS gets it wrong. At Geoff's suggestion, I use the epics IOC shell function
dbtgf "PV"
to print the update time, along with other info like this
-> dbtgf "CC2_KLY:ildb0:wave9Flat"
status=0 severity=0
units= precision=4
time=558040636 315109960
And the first part of the time there is supposed to be seconds since Jan 1 1990 (not 1970)
which should be 631152000 less than the time since 1970
(3600*24*(365*20+5leapdays)) = 631152000
Anyway, the time I get from dbtgf is also exactly one hour earlier than it should be
(after I convert by adding 631152000 then comparing to unix's seconds since 1970).
The dbtgf time matches the camonitor time, both being one hour early.
I even tried to force things a bit by adding these lines to the beginning of my vxworks boot script:
putenv "TIMEZONE=PSTPDT::480:031102:110402"
putenv "EPICS_TS_MIN_WEST=480"
I'm really in the Central time zone, but I thought I would make it think I was Pacific time, just
to see what happens.
And after that on vxworks,
date() does print out the time as it should be in the Pacific zone (two hours earlier
than central), but when I do camonitor on my central time zone unix machine, it still
tells me the PV update time is one hour too early (one hour earlier than the actual CDT time here now).
I have run with and without the correct TIMEZONE setting, which is
putenv "TIMEZONE=CSTCDT::360:031102:110402"
but it doesn't make any difference, as well it shouldn't since we are in the middle of CST and not
on the newly-changed-this-year shoulder dates in March or Nov.
I get this behaviour with my epics objects built with 3.14.7 and 3.14.8.2.
(I had been running 3.14.7 but decided to upgrade since I thought maybe that was causing the problem here).
vxworks version 5.4
camonitor is 3.14.8.2 and the archiver is built against 3.14.8.2 I believe.
What do I have to do to get epics the correct time?
Thanks
Dennis
[email protected]
RE: epics vxworks time off by 1 hour Jeff Hill
Re: epics vxworks time off by 1 hour Kay-Uwe Kasemir
Prev: RE: CA server problem on caserverio.c Jeff Hill
Next: RE: epics vxworks time off by 1 hour Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ASYN - weird Andrew Johnson
