1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA server problem on caserverio.c
To: "'Zhichu Chen'" <[email protected]>, <[email protected]>
Date: Fri, 7 Sep 2007 11:52:47 -0600
Hello Chen,
I created entry 300 in the Mantis bug tracking system. Feel; free to add any comments there that you might have.
I don’t have a stack trace so I am attempting to infer the cause based on quite a few different paths through the code to this particular assert failure. After some analysis I can identify two possible causes.
1)     A string, a scalar DBR_STRING of type dbr_string_t, that somehow isn’t nill terminated is passing through the database to the CA server.
2)     The server is printing a diagnostic message and a record name, as obtained with “RECORD_NAME ( paddr )” form the database API, is unusually long (perhaps it is corrupt or alternatively it isn’t nill terminated).
I can easily detect (1) and fix it in the scalar case. Thanks to C99 we also now have functions like vsnprintf and I can easily make the code robust against (2).
I committed patches to R3.14 for both (1) and (2).
It would be very interesting to see if this fix resolves your problem. To test you have two options.
1)     Attempt to patch R3.14.9 with the diffs provided below (that might be somewhat susceptible to human error)
2)     Wait for the next CVS snapshot to come around for the EPICS R3.14 branch, and fetch a complete copy of the latest R3.14.10 efforts (only for testing purposes).
Thanks for any help that you can provide with testing.
Jeff Hill
Index: camessage.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/rsrv/camessage.c,v
retrieving revision 1.105.2.10
diff -c -b -r1.105.2.10 camessage.c
*** camessage.c   17 Aug 2007 22:31:10 -0000    1.105.2.10
--- camessage.c   7 Sep 2007 17:03:09 -0000
*** 24,29 ****
--- 24,30 ----
  #include "osiSock.h"
  #include "osiPoolStatus.h"
  #include "epicsEvent.h"
+ #include "epicsStdio.h"
  #include "epicsThread.h"
  #include "epicsMutex.h"
  #include "epicsTime.h"
*** 134,139 ****
--- 135,141 ----
  va_list                 args
+     static const ca_uint32_t    maxDiagLen = 512;
      struct channel_in_use       *pciu;
      caHdr                       *pReqOut;
      char                        *pMsgString;
*** 174,180 ****
       * allocate plenty of space for a sprintf() buffer
      localStatus = cas_copy_in_header ( client,
!         CA_PROTO_ERROR, 512, 0, 0, cid, status,
          ( void * ) &pReqOut );
      if ( localStatus != ECA_NORMAL ) {
          errlogPrintf ( "caserver: Unable to deliver err msg \"%s\" to client because \"%s\"\n",
--- 176,182 ----
!         CA_PROTO_ERROR, maxDiagLen, 0, 0, cid, status,
*** 215,223 ****
       * add their context string into the protocol
!     status = vsprintf ( pMsgString, pformat, args );
!     if ( status >= 0 ) {
!         size += ( ( ca_uint32_t ) status ) + 1u;
      cas_commit_msg ( client, size );
--- 217,236 ----
!     localStatus = epicsVsnprintf ( pMsgString, maxDiagLen, pformat, args );
!     if ( localStatus >= 1 ) {
!         unsigned diagLen = ( unsigned ) localStatus;
!         if ( diagLen < maxDiagLen ) {
!             size += (ca_uint32_t) (diagLen + 1u);
!         else {
!             errlogPrintf (
!                 "caserver: vsend_err: epicsVsnprintf detected "
!                 "error message truncation, pFormat = \"%s\"\n",
!                 pformat );
!             size += maxDiagLen;
!             pMsgString [ maxDiagLen - 1 ] = '\0';
*** 495,501 ****
      struct channel_in_use *pciu = pevext->pciu;
      const int readAccess = asCheckGet ( pciu->asClientPVT );
      int status;
-     int strcnt;
      int v41;
      SEND_LOCK ( pClient );
--- 508,513 ----
*** 575,581 ****
      else {
!         ca_uint32_t msgSize = pevext->size;
          int cacStatus = caNetConvert (
              pevext->msg.m_dataType, pPayload, pPayload,
              TRUE /* host -> net format */, pevext->msg.m_count );
--- 587,593 ----
      else {
!         ca_uint32_t payloadSize = pevext->size;
*** 586,601 ****
              if ( pevext->msg.m_dataType == DBR_STRING
                  && pevext->msg.m_count == 1 ) {
!                 /* add 1 so that the string terminator will be shipped */
!                 strcnt = strlen ( (char *) pPayload ) + 1;
!                 msgSize = strcnt;
          else {
!             memset ( pPayload, 0, msgSize );
              cas_set_header_cid ( pClient, cacStatus );
!         cas_commit_msg ( pClient, msgSize );
--- 598,622 ----
!                 char * pStr = (char *) pPayload;
!                 size_t strcnt = strlen ( pStr );
!                 if ( strcnt < payloadSize ) {
!                     payloadSize = ( ca_uint32_t ) ( strcnt + 1u );
!                 else {
!                     pStr[payloadSize-1] = '\0';
!                     errlogPrintf (
!                         "caserver: read_reply: detected DBR_STRING w/o nill termination "
!                         "in response from db_get_field, pPayload = \"%s\"\n",
!                         pStr );
          else {
!             memset ( pPayload, 0, payloadSize );
!         cas_commit_msg ( pClient, payloadSize );
*** 620,626 ****
      ca_uint32_t payloadSize;
      void *pPayload;
      int status;
-     int strcnt;
      int v41;
      if ( ! pciu ) {
--- 641,646 ----
*** 686,698 ****
       * boundary
      if ( mp->m_dataType == DBR_STRING && mp->m_count == 1 ) {
!         cas_commit_msg ( pClient, strcnt );
      else {
      SEND_UNLOCK ( pClient );
--- 706,725 ----
       * boundary
          else {
!             errlogPrintf (
!                 "caserver: read_action: detected DBR_STRING w/o nill termination "
!                 pStr );
+     cas_commit_msg ( pClient, payloadSize );
From: [email protected] [mailto:[email protected]] On Behalf Of Zhichu Chen
Sent: Thursday, September 06, 2007 9:40 PM
To: [email protected]
Subject: CA server problem on caserverio.c
I've written an ioc (using TekVISA from Tektronix on a DPO7054 Oscilloscope, Windows XP) and it starts okay at first. But when it runs for like several minutes, I got an error like:
A call to "assert (size <= ntohs ( pMsg->m_postsize ))" failed in ..\caserverio.
c line 344.
EPICS Release EPICS R3.14.5 $R3-14-5$ $2004/02/04 20:45:33$.
Current time Fri Sep 07 2007 09:49:29.518463915 .
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
then it stunks. I suppose that the cas_commit_msg function checks the pMsg->m_postsize and finds out it's larger than size. But I don't know how these variables come from.
I'm sorry I'm just new to EPICS and have few experiences about C programming. Could any of you give me a clue that what's happenning now? Any input is welcome.
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
CA server problem on caserverio.c Zhichu Chen
Prev: Re: ASYN - weird Andrew Johnson
Next: epics vxworks time off by 1 hour Dennis Nicklaus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA server problem on caserverio.c Zhichu Chen
Next: ASYN - weird Heinrich du Toit
