1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RT linux
To: Emmanuel Mayssat <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Mon, 10 Sep 2007 12:24:35 -0500
hallo,
Emmanuel Mayssat wrote:
Hello,
I was wondering what would justify moving to RT linux?
it's free....
I was actually contemplating doing the move to RT myself, but finally
decided against it.
All RT-required feedback/acquisition/etc are implemented in
hardware/electronics. As a result, my IOCs don't have to react
Real-Time.
But could you describe a "real" situation where RT is necessary?
Maybe if you have an IOC which is connected to a device that generate
hardware interrupts, etc. but so far I never encountered such a device.
using the standard linux kernel with the osadl patch addresses interrupt latency issues. i was particularly
interested in that. on the ebrick, i'm using hardware interrupts from the oms pc78-46 module to signal
when a motor is done, and other modules supported by the ebrick.
E
On Mon, 2007-09-10 at 05:59 -0500, David Kline wrote:
you can use >=2.6.18 linux kernel/w patch from osadl
(http://www.osadl.org/). that will give you rt behavior.
/david
Heinrich du Toit wrote:
Hi
Did somebody else out there use RTLinux for EPICS?
-Heinrich
David M. Kline                   [email protected]
Beamline Controls and Data Acquisition (BCDA)
Argonne National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
                   Beamlines R Us
RT linux Heinrich du Toit
Re: RT linux David Kline
Re: RT linux Emmanuel Mayssat
Prev: Re: RT linux Emmanuel Mayssat
Next: Re: RT linux John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
