1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RT linux
To: TechTalk EPICS <[email protected]>
Date: Tue, 11 Sep 2007 10:26:19 +0200
I have this stupid old hardware system.
It is actually very simple. It controls a stepper motor.
But you only have stop/go command
and a analog feedback
but the feedback lags a bit.
This requires you to quite accurately issue stop/go to this device to
position the motor :)
Anyways I think I'm rather going to replace hardware than try to make
this hardware work on new software.
I'm after all actually an engineer ... and not just a programmer :D
On Mon, 2007-09-10 at 09:43 -0700, Emmanuel Mayssat wrote:
> Hello,
> I was wondering what would justify moving to RT linux?
> I was actually contemplating doing the move to RT myself, but finally
> decided against it.
> All RT-required feedback/acquisition/etc are implemented in
> hardware/electronics. As a result, my IOCs don't have to react
> Real-Time.
> But could you describe a "real" situation where RT is necessary?
> Maybe if you have an IOC which is connected to a device that generate
> hardware interrupts, etc. but so far I never encountered such a device.
> Thanks,
> E
> On Mon, 2007-09-10 at 05:59 -0500, David Kline wrote:
> > you can use >=2.6.18 linux kernel/w patch from osadl
> > (http://www.osadl.org/). that will give you rt behavior.
> > /david
> > Heinrich du Toit wrote:
> > > Hi
> > > Did somebody else out there use RTLinux for EPICS?
> > > -Heinrich
RT linux Heinrich du Toit
Re: RT linux David Kline
Re: RT linux Emmanuel Mayssat
Prev: RE: asyn for synchronous devices Heinrich du Toit
Next: Re: asyn for synchronous devices John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RT linux John Sinclair
Next: graphical operator interface based on JAVA Aditya Mandal
