1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: host watchdog and PLC
To: John Sinclair <[email protected]>
Cc: [email protected]
Date: Mon, 17 Sep 2007 15:12:15 -0700
John,
There are several issues with power cycling all of which I experienced
at one point.
1/ The operator needs to know which unit to power cycle. Given the
distributed nature of EPICS, this may not be obvious.
2/ During power cycle procedure you do not have any control, so the
synchrotron is in an unknown, uncontrollable state which is exactly what
I want to avoid.
3/ A power cycle resets all output signals (to zero) even if they are
later restored to their previous values. This is particularly true for
DAC PCI cards with AO and BO.
In the past and for other reasons, I looked at those networked power
strips (a.k.a PDU or power distribution unit). The company called Server
Technology (http://www.servertech.com) had some impressive products.
Their products are designed for rack mountable equipment up to
22kW/30A.
A console server would be a great complement as well. But PDU and
console servers do not guarantee I know the state of my synchrotron at
all time.
E
On Sat, 2007-09-15 at 09:08 -0400, John Sinclair wrote:
> Emmanuel,
> I, for one, never rely on an EPICS IOC to protect property or personnel.
> If an IOC
> experiences a software-related lock-up, I cycle its power. If it resides
> in an
> inaccessible location, I connect to a special network-attached device
> via telnet
> to perform the power cycle. In the worst case, this causes a small change in
> some output (values are saved every ten seconds so we can loose a change
> that occurs immediately before the failure).
> John Sinclair
Re: host watchdog and PLC Maren Purves
host watchdog and PLC Emmanuel Mayssat
Re: host watchdog and PLC John Sinclair
Prev: Deadlock on epicsEvent Denison, PN (Peter)
Next: Re: host watchdog and PLC Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: host watchdog and PLC John Sinclair
