1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: host watchdog and PLC
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Mon, 17 Sep 2007 12:31:09 -1000
Emmanuel Mayssat wrote:
John,
There are several issues with power cycling all of which I experienced
at one point.
1/ The operator needs to know which unit to power cycle. Given the
distributed nature of EPICS, this may not be obvious.
that's why it's a good idea to give iocs and records and everything else involved names that mean something.
2/ During power cycle procedure you do not have any control, so the
synchrotron is in an unknown, uncontrollable state which is exactly what
I want to avoid.
but, if it's locked up you are already in that state.
3/ A power cycle resets all output signals (to zero) even if they are
later restored to their previous values. This is particularly true for
DAC PCI cards with AO and BO.
If you don't want to power cycle, there's such things as console switches (I guess that's what you're talking about below) as well from which you can do (and watch) soft reboots.
A console server would be a great complement as well. But PDU and
console servers do not guarantee I know the state of my synchrotron at
all time.
In real life you never can. The best you can do is make sure that when it fails it fails in a safe manner. Hardware breaks by itself, and power outages aren't always avoidable (or predictable) either. (And earthquakes?)
Maren
On Sat, 2007-09-15 at 09:08 -0400, John Sinclair wrote:
Emmanuel,
I, for one, never rely on an EPICS IOC to protect property or personnel. If an IOC
experiences a software-related lock-up, I cycle its power. If it resides in an
inaccessible location, I connect to a special network-attached device via telnet
to perform the power cycle. In the worst case, this causes a small change in
some output (values are saved every ten seconds so we can loose a change
that occurs immediately before the failure).
John Sinclair
host watchdog and PLC Emmanuel Mayssat
Re: host watchdog and PLC John Sinclair
Re: host watchdog and PLC Emmanuel Mayssat
Prev: Re: host watchdog and PLC Emmanuel Mayssat
Next: Re: host watchdog and PLC Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
