1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: confusion with config dir in base
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 19 Sep 2007 08:19:00 -0500
config    = EPICS base 3.13 and earlier
configure = EPICS base 3.14 and beyond
If you use auto completion of the directory name you go to the wrong place if you are not careful. You could complain about this choice but the experts always have a good answer as to why the choice was made.
Geoff
On Sep 19, 2007, at 6:50 AM, Heinrich du Toit wrote:
Hi
I've just had a hard time with this.
I wanted to change the way base compile.
And I kept on editing the file in base/config/CONFIG.something
but it doens't help.
Then after a long time spent trying to figure out what is going on I see
that base/config aint used.
But rather base/configure/os/
so my question is... what is the point of base/config?
does it have something todo with extensions or something else later on?
-Heinrich
Re: confusion with config dir in base Andrew Johnson
confusion with config dir in base Heinrich du Toit
Prev: Re: exceed Geoff Savage
Next: Re: Asyn/VXI-11 problems Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: confusion with config dir in base Heinrich du Toit
Next: Re: confusion with config dir in base Andrew Johnson
