1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: confusion with config dir in base
To: Geoff Savage <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 19 Sep 2007 09:33:37 -0500
Geoff Savage wrote:
config    = EPICS base 3.13 and earlier
configure = EPICS base 3.14 and beyond
If you use auto completion of the directory name you go to the wrong place if you are not careful. You could complain about this choice but the experts always have a good answer as to why the choice was made.
In this case (as in many others too) the reason for having both was for backwards compatibility. It is only fairly recently that we have published versions of the APS extensions programs that use the R3.14 build system (i.e. base/configure), so for a long time base/config was used for building most extensions programs and base/configure for IOC applications and support modules.
The base/config directory will be going away in the next major release of EPICS Base, so if anybody still has any extensions code that still uses Makefile.Host I suggest you consider converting it, although I'm not seriously expecting R3.15 to be released before 2009 at the earliest.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
confusion with config dir in base Heinrich du Toit
Re: confusion with config dir in base Geoff Savage
Prev: Use of waveform records Touchard Dominique
Next: Re: Use of waveform records Dave Reid
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: confusion with config dir in base Geoff Savage
Next: Use of waveform records Touchard Dominique
