we are working on/with the Epics modbus tcp driver written by Mark
Rivers. We need to write a 32 bits integer value in a power supply
command control interface. First we thought to write an asyn32Int
record with the number 6 modbus function. Immediatly, we saw that the
driver uses the number 6 modbus function which works only on a 16 bits word.
After reading the Modbus Driver Support documentation, we saw that we
have to use a two value length waveform record.
First question : is this correct ?
Second question : do we have to use the gensub record to manipulate
values inside a waveform record ? In this case, is there any example
that shows how to do this ? Could somebody send us an example on this ?
Third question : Is a bad idea to modify the modbus driver in the goal
to write a asyn32Int 32 bits integer record with the number 16 modbus
function ?
Thanks for your help .
Dominique Touchard.
- Re: Use of waveform records Dave Reid
- RE: Use of waveform records Mark Rivers
Re: Asyn/VXI-11 problems Benjamin Franksen
Re: confusion with config dir in base Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
