On Wednesday 19 September 2007 21:37, Szalata, Zenon M. wrote:
> I am having difficulties installing a support package for Agilent E2050
> ethernet-GPIB gateway device. I got the package from
> http://www-csr.bessy.de/control/SoftDist/gpib/ The installation
> instructions are not clear. This is an extract from the lanGpib.pdf
> file:
> This section explains how the lanGpib driver is installed in an existing
> EPICS environment. By far the easiest way to install the package is to
> create a seperate <top> area (named, for example, 'GPIB') with
> makeBaseAp.pl (this requires that you use EPICS3.13.1 or later). Copy the
> tar file into the new <top> directory and unpack it. You may need to
> adapt the config/RELEASE resp. config/RELEASE.<arch> to your local EPICS
> configuration. Then 'make' everything from the <top> directory.
> First of all I assume that the author of the note ment makeBaseApp.pl in
> epics base? Perhaps not. The Makefiles which came with the package are
> inconsistent with existing file names and directory structure created by
> the makeBaseApp.pl. I am trying to install in the context of epics
> R3.14.9. The instructions provided with the distribution seem out of
> date. I guess I need up to date instructions. Any help will be
> appreciated.
All the modules from that site are for EPICS 3.13 only. For 3.14 you should
use asyn. lanGpibSupport-2.4.c is a very old version that I don't recommend
to use. I won't provide support or fixes for this version. I still support
gpib-0.x, although it is not actively developed any longer and the last
release is from Jan 2006.
Cheers
Ben
- Re: lanGpibSupport-2.4.c Eric Norum
- Byte Order? Szalata, Zenon M.
- lanGpibSupport-2.4.c Szalata, Zenon M.
Re: exceed Jiro Fujita
Re: Asyn/VXI-11 problems Benjamin Franksen
<2007>
2025
2026
<2007>
2025
2026
