1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn/VXI-11 problems
To: [email protected]
Date: Fri, 21 Sep 2007 12:30:18 +0200
On Thursday 20 September 2007 16:16, Eric Norum wrote:
> It appears to be faulting inside the RPC library clnttcp_create
> routine.  Are there any diagnostics you can enable for that library?
> Do you have the source so you could check what's happening in the
> library code?
Having a hard time to believe that the RPC implementation is at fault here,
I pursued a different path and with success. The backtrace is misleading
(or should I say, wrong?), since the point where the IOC crashes is really
in clnt_destroy, not in clnttcp_create.
The fault, it seems, is in the routine vxiConnectPort (in
asyn/vxi11/drvVxi11.c). vxiConnectPort calls clnttcp_create and afterwards
calls vxiBusStatus. If vxiBusStatus fails, vxiConnectPort calls
ctln_destroy. However, if vxiBusStatus fails it has already called
clnt_destroy, since it is implemented using clntCall, which calls
vxiDisconnectPort on failure, which calls clnt_destoy.
Thus, clnt_destroy gets called a second time, causing the crash.
I have veryfied all this multiple times by adding enough breakpoints (all
call sites of clnt_create (1) and clnt_destroy (7) in
I have not produced a fix for this problem. I guess you (Eric) know better
how to approach this.
Cheers
Ben
Re: Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Eric Norum
Prev: Re: exceed David Kline
Next: Re: Asyn/VXI-11 problems Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn/VXI-11 problems Eric Norum
