1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA inside IOC - shutdown problem
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 28 Sep 2007 13:09:20 -0500
Heinrich du Toit wrote:
Everything works fine but at shutdown I get some funny errors at times.
This is a known problem on Linux distributions that use the NPTL (the New Posix Thread Library).
One thing that happens is I get:
epicsThreadOnceOsd epicsMutexLock failed
And other times I get:
epicsThread: Unknown C++ exception in thread "CAC-UDP" at Fri Sep 28
2007 08:39:57.528629432
terminate called after throwing an instance of ''
FATAL: exception not rethrown
Aborted (core dumped)
That particular error is an interaction between C++ and the NPTL: NPTL uses the C++ exception mechanism to cause Posix thread cleanup routines to be called when the process exits, but the thing that it throws can't be caught by any C++ code. Unfortunately in EPICS Base we mix Posix and C++, and the result is the above error on shutdown. The error appears to be harmless in my experience.
But this doesn't happen everytime.
Seem to be something todo with timing during exit?
I have a hooked epicsatExit function.
This makes sure ca_clear_channel is called for every CHID I have.
I don't call ca_destroy_context as that seem to be done by shutdown
itself?
Can somebody just give me a tip on what those error messages mean? Then
maybe I can guess what the bug is.
I'm not sure about the "epicsMutexLock failed" error although it is most likely that it's related, but we do know that the IOC code is not good at shutting itself down cleanly â it was designed to run on an embedded vxWorks CPU whose only job was to run that IOC code, and shutdown wasn't considered to be important functionality. As a result we don't have the mechanisms in place in our APIs to notify records or device support to shut themselves down. It's likely that we will not be able to properly address this problem in current versions of EPICS, although if/when we redesign the record and device APIs shutdown will be one of the design requirements.
Also sometimes (1 out of 30+ times) I get a segfault while starting the
IOC?  Is it dangerous todo some CA stuff during some stages of the IOC
startup?
You should probably avoid using the CA client library before the startup script's call to iocInit has completed. After that is fine, but do register an epicsAtExit() routine (after iocInit) and have that stop any threads and CA calls from occurring afterwards.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
CA inside IOC - shutdown problem Heinrich du Toit
Prev: EPICS - Future Plans: your Input Matthias Clausen
Next: Support module for KS3988 camac crate controller. Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA inside IOC - shutdown problem Heinrich du Toit
Next: EPICS - Future Plans: your Input Matthias Clausen
