On vxWorks using the target shell you can say dbBptNotMonotonic=1 in your startup script. For the other architectures that use the IOC Shell, use the syntax var dbBptNotMonotonic 1 Note that for the latter case your src/misc/base.dbd file must have variable(dbBptNotMonotonic,int) in it; I might have left that addition out of the patch. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
