1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards
To: Jenny Chen <[email protected]>
Cc: [email protected]
Date: Mon, 08 Oct 2007 09:41:04 -0700
On Mon, 2007-10-08 at 16:28 +0800, Jenny Chen wrote:
> Thanks a lot if you can send me a copy. We may have a cPCI crate with
> an
> Intel CPU and four DI/DO/AI/AO cards soon. The OS might be Fedora
You may want to look at comedi.org for Data acquisition drivers.
> cPCI cards is similar or not? One more question, is it difficult to
> handle interrupt from cPCI cards?
You probably won't need interrupts. You ADC cards probably have an
on-board buffer to which they write to according to their trigger rate.
Your driver should mmap that buffer and read all of the valid data ( X
waveforms for X on-board channels). Of course, your epics scan rate has
to be fast enough to prevent the buffer from filling up.
Good luck,
E
RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Jenny Chen
Prev: Re: PV aliases Andrew Johnson
Next: Re: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Jenny Chen
