1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice (was: Re: Asyn/VXI-11 problems)
To: [email protected]
Date: Tue, 9 Oct 2007 15:31:48 +0200
On Tuesday 09 October 2007 14:29, Dirk Zimoch wrote:
> Benjamin Franksen wrote:
> > Ok, I've found one bug in stream version 2-2 that leads to a crash. A
> > format of "%*[whatever>]"
> > gets converted internally to "%0[whatever>]%n" and then only /one/
> > pointer arg is provided to sscanf, instead of two. The method where
> > sscanf crashes is in StreamFormatConverter.cc:
> This bug had been reported to me by Emma Shepherd on August 27.
> A patch
> to fix this bug is available on the StreamDevice web page since the same
> day.
Hi Dirk
Sorry. I /did/ try the latest snapshot, that was the first thing I tried.
However, at this time I wasn't aware that we had two bugs at the same time,
the other one being in asyn/vxi-11. I learned that only later and it seems
I forgot to check with the snapshot version for a second time.
> If you find bugs, I can only fix them if you report them!
I thought posting on tech-talk would be enough to report a bug in
streamDevice. Should I CC you when reporting a bug?
Cheers
Ben
Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Dirk Zimoch
Prev: Re: Asyn/VXI-11 problems Dirk Zimoch
Next: RE: Use of waveform records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Asyn/VXI-11 problems J. Lewis Muir
