1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn/VXI-11 problems
To: [email protected]
Date: Tue, 09 Oct 2007 10:01:58 -0400
On 10/9/07 8:29 AM, Dirk Zimoch wrote:
Hi Ben,
Just coming back from vacation I found this:
Benjamin Franksen wrote:
Ok, I've found one bug in stream version 2-2 that leads to a crash. A format of "%*[whatever>]"
gets converted internally to "%0[whatever>]%n" and then only /one/ pointer arg is provided to sscanf, instead of two. The method where sscanf crashes is in StreamFormatConverter.cc:
This bug had been reported to me by Emma Shepherd on August 27. A patch to fix this bug is available on the StreamDevice web page since the same day.
If you find bugs, I can only fix them if you report them!
Watch the web page for patches.
Dirk
Hi, Dirk.
Just a suggestion, why not make a new release, say version 2.2.1, instead of making a patch available? This would have likely prevented Benjamin's confusion. Also, it's easy to download the latest version, it's more work to download each patch and figure out how they should be applied.
If you do stick with the release + patches approach, I think that making the patches available right next to the release like you do is a good idea. Some projects have a Known Problems link one has to click on in order to even find patches; this tends to lead to more than one person reporting the same bug or running into the same problem because they didn't know there was a patch for it already.
-lewis
int StdCharsetConverter:: scanString(const StreamFormat& fmt, const char* input, char* value, size_t maxlen) { int length = -1; if (fmt.flags & skip_flag) { if (sscanf (input, fmt.info, &length) < 0) return -1; } ....
Since skip_flag is set only for %* formats, it is wrong to replace it with %0. Thus the parse method must be changed, like this (see comments):
parse(const StreamFormat& fmt, StreamBuffer& info,
const char*& source, bool scanFormat)
if (!scanFormat)
error("Format conversion %%[ is only allowed in input formats\n");
return false;
if (fmt.flags & (left_flag|sign_flag|space_flag|zero_flag|alt_flag))
error("Use of modifiers '-', '+', ' ', '0', '#'"
"not allowed with %%%c conversion\n",
fmt.conv);
return false;
if (scanFormat && fmt.prec >= 0)
error("Use of precision field '.%d' not allowed with %%%c input conversion\n",
fmt.prec, fmt.conv);
return false;
// fix: bfr 20/09/07
if (fmt.flags & skip_flag ) {
info.printf("%%*[");
else {
info.printf("%%%d[", fmt.width);
// end fix
while (*source && *source != ']')
if (*source == esc) source++;
info.append(*source++);
if (!*source) {
error("Missing ']' after %%[ format conversion\n");
return false;
source++; // consume ']'
info.append("]%n");
return string_format;
However, the IOC crashes anyway, because this is just one of many bugs. I'll send more debugger output soon.
Cheers
Ben
Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Eric Norum
Re: Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Dirk Zimoch
Prev: RE: Use of waveform records Mark Rivers
Next: VME-GPIB replacement for GPIB-1014D Waggoner, Bill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StreamDevice (was: Re: Asyn/VXI-11 problems) Benjamin Franksen
Next: Beginer problem V . I . Stoica
