1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500)
Cc: Daron Chabot <[email protected]>, [email protected]
Date: Wed, 10 Oct 2007 11:42:27 -0700
Hello all,
I tried frame grabber, etc. recently decided to move to an AXIS video
server. The asyn/epics driver is in development. We are reading the
mjpeg video stream (using the GPL code from axmjpeg). The throughput of
the video stream on the network can be throttled on the server side. We
use interrupt to trigger frame processing.
We completed performance testing. We can achieve the 30 frames per
second benchmark. I was shocked with the achieved performance. This
solution rocks! I gave myself a pat on the back just for thinking of it!
Load on cpu < 5%, load on local area network... negligible.
What takes time is the processing of each frame (background subtraction,
ROI, intensity monitor, etc.), so this part needs to be optimized. This
is actively being developed/reviewed.
Emmanuel
>         > Here at the CLS we're using linux-based soft IOCs to
>         > communicate with Flea and Flea2 cameras.
>         > We're having difficulty in achieving video frame rates
>         > greater than about 10 Hz at 640x480 resolution. I'm
>         > interested to know how you are getting such fine performance
>         > (aside from using RTEMS :-)
Re: Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500) Emmanuel Mayssat
Re: Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500) Steve Shoaf
RE: firewire video on RTEMS-4.6.x-MVME5500 Mark Rivers
Prev: ICALEPCS07 conference Kate Feng
Next: Re: Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500) Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: firewire video on RTEMS-4.6.x-MVME5500 Daron Chabot
