1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn interrupt and record
To: TechTalk EPICS <[email protected]>
Date: Fri, 12 Oct 2007 12:36:12 +0200
If I have a custom record...
And it has some procedure to respond to an ASYN interrupt.
As I understand it this asyn interrupt run in a different thread than
the dbaccess for the record?
This means in effect that if I have some array field and start editing
it in the interrupt function.
Then the db access/ca can get half-way modified values back?
Which would be bad?
Any method that the array can mutex/lock its fields while processing
them?
Or is it ok to edit?
RE: asyn interrupt and record Mark Rivers
Prev: RE: firewire video on RTEMS-4.6.x-MVME5500 Pearson, MR (Matthew)
Next: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StreamDevice 2-3 released Dirk Zimoch
Next: RE: asyn interrupt and record Mark Rivers
