> This means in effect that if I have some array field and start editing
> it in the interrupt function.
> Then the db access/ca can get half-way modified values back?
No, that is not a problem. The interrupt callback will call dbScanLock to lock the record before it modifies anything. Of course that can block, but if the database is built correctly then it will not block for long, because any asynchronous processing will be happening in other threads. This is the standard EPICS method to avoid conflicts with record processing.
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 10/12/2007 5:36 AM
To: TechTalk EPICS
Subject: asyn interrupt and record
If I have a custom record...
And it has some procedure to respond to an ASYN interrupt.
As I understand it this asyn interrupt run in a different thread than
the dbaccess for the record?
Which would be bad?
Any method that the array can mutex/lock its fields while processing
them?
Or is it ok to edit?
- asyn interrupt and record Heinrich du Toit
Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Emmanuel Mayssat
<2007>
2025
2026
softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
<2007>
2025
2026
