The first thing I would try is to set EPICS_CAS_BEACON_ADDR_LIST...
There was just a thread about this last week ;-)
http://www.aps.anl.gov/epics/tech-talk/2007/msg01150.php
If you use ports in EPICS_CA_ADDR_LIST (client search request), you will
need to set EPICS_CAS_BEACON_ADDR_LIST (server beacon) manually.
I think the problem you are experimenting is that the beacons are sent
to the same port where search requests only are expected.
EPICS_CAS_BEACON_ADDR_LIST default to EPICS_CA_ADDR_LIST if not set.
Check the server configuration (EPICS_CAS_* envvars) in the channel
access reference manual for more info.
Let us know if it worked!
Emmanuel
On Fri, 2007-10-12 at 14:19 +0200, Dirk Zimoch wrote:
> Hi Jeff and others,
> I see strange crashes of the CA gateway which probably originate in the CAS code.
> If I use an explicit port in EPICS_CA_ADDR_LIST like this
> EPICS_CA_ADDR_LIST="gateway:5066"
> and then start a softioc running a record with an INP link to a record behind
> the gateway (running on that port), the gateway starts printing errors and
> refuses to handle any more requests. It has to be restarted.
> The gateway prints:
> CAS: CAS Request: ? on pc3853.psi.ch:38210: cmd=13 cid=0 typ=11 cnt=5064 psz=0
> avail=81818260
> Oct 12 14:01:36 !!! Errlog message received (message is above)
> bad request code=13 in DG
> filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
> protocol from client was invalid unexpected problem with UDP input from
> "pc3853.psi.ch:38210"
> avail=81818260
> However, a simple caget works without problems, at least before the softioc
> crashes the gateway.
> I tried 3.14.8 and 3.14.9 on the ioc side. The gateway runs with some pre-3.13.9
> CVS snapshot. But I also tried it with the 3.14.9 libraries.
> BTW: I could not recompile the gateway with 3.14.9, because the function
> epicsNTOH16 does not exist any more. I had to trick the 3.14.9 libraries into
> the gateway's library search path.
> Please, don't remove API functions when changing Channel Access!
> Any idea?
> Dirk
- Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
- softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
RE: asyn interrupt and record Mark Rivers
RE: ASYN - calling read after interrupt - fix :) Mark Rivers
<2007>
2025
2026
<2007>
2025
2026
