Subject: |
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) |
Robert Soliday <[email protected]> |
To: |
TechTalk EPICS <[email protected]> |
Date: |
Mon, 15 Oct 2007 09:50:59 -0500 |
If I remember correctly, the ccmra version of openmotif does not put the libraries and headers into /usr/lib. I believe you will have to edit extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86 and change the X11_LIB, X11_INC, MOTIF_LIB, and MOTIF_INC variables to point to the correct location.
----- Original Message -----
Date: Monday, October 15, 2007 1:19 am
Subject: Re: fedora core 7 medm (was >> Re: MEDM compile - update :)
> Hi
> I'm really not the expert but with lesstif I found some other problems
> later on. Like menu's nog working or buttons not reacting and things
> like that.
> So I found the motif packages somewhere and compiled with that.
> works much better.
> You thing is not finding some header files it seems....
> Xm.h ect
> On my system: (ubuntu feisty)
> Xm.h & XmP.h is inside libmotif-dev
> It seems Label.h is inside libxaw-headers
> Obviously I can't really say where these files are under Fedora..
> But it seems like you are missing some required files to compile MEDM.
> On Sun, 2007-10-14 at 05:19 +0200, Mauro Giacchini wrote:
> > Heinrich du Toit wrote:
> > > Recently libmotif-dev has been replaced with lesstif2-dev
> > > (under ubuntu anyways)
> > > therefore...
> > > in the file medm/xc/Matrix.c there is a line (44 about):
> > > /* Internal Motif functions not defined in header files */
> > > void _XmDrawShadow();
> > > Well under ubuntu we used to have libmotif-dev package for
> which this
> > > was needed.
> > > This has been replaced with lesstif2-dev
> > > Now the line is no longer needed.
> > > Infact it gives a compile error if it is there
> > > Further:
> > > in medm/xc/WheelSwitch.c:
> > > line 232:
> > > Widget _XmGetTabGroup();
> > > Change this to:
> > > /*Widget _XmGetTabGroup();*/
> > > #define _XmGetTabGroup XmGetTabGroup
> > > As XmGetTabGroup is defined now!
> > > I'm still getting these warnings inside xc folder compile:
> > > gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -D_X86_
> > > -Dlinux -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE -I. -I..
> > > -I/usr/X11R6/include -I/usr/X11R6/include/X11
> > > -I../../../../include/os/Linux -I../../../../include
> > > -I/epics/base/include/os/Linux -I/epics/base/include
> > > -c ../WheelSwitch.c
> > > ../WheelSwitch.c: In function ‘Initialize’:
> > > ../WheelSwitch.c:687: warning: passing argument 1 of
> > > ‘_XmGetFocusPolicy’
> > > from incompatible pointer type
> > > ../WheelSwitch.c: In function ‘btn1DownProc’:
> > > ../WheelSwitch.c:2831: warning: passing argument 1 of
> > > ‘_XmDispatchGadgetInput’ from incompatible pointer type
> > > ../WheelSwitch.c: In function ‘enterWindowProc’:
> > > ../WheelSwitch.c:3040: warning: passing argument 1 of
> > > ‘_XmGetFocusPolicy’ from incompatible pointer type
> > > ../WheelSwitch.c: In function ‘leaveWindowProc’:
> > > ../WheelSwitch.c:3066: warning: passing argument 1 of
> > > But medm compiles and seems to work :)
> > Using your instruction the medm compile but when starts:
> > Trying default (fixed) instead
> > MEDM Version 3.1.2.1: Loading aliased fonts.................
> > SIGSEGV
> > Aborted
> > then crash. I'm using openmotif-2.3.0-0 ..fc7.ccmra.i386.rpm
> > and lesstif-devel-0.95-0-20.fc7.i386.rpm
> > Reading old emails about this (to fc6) I've removed lesstif and
> install> openmotif-devel-2....7.cmra.i386.rpm ; in this case it
> didn't compile:
> > /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> > -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
> > -D_REENTRANT -ansi -O3 -Wall -g -fPIC -I. -I..
> > -I/opt/epics/modules/asyn4-8/include/os/Linux
> > -I/opt/epics/base-3.14.9/include/os/Linux
> > -I/opt/epics/base-3.14.9/include -I/usr/include -I/usr/include/X11
> > ../Caption.c
> > ../Caption.c:30:20: error: Xm/XmP.h: No such file or directory
> > ../Caption.c:33:22: error: Xm/Label.h: No such file or directory
> > In file included from ../CaptionP.h:36,
> > from ../Caption.c:34:
> > ../Caption.h:36:19: error: Xm/Xm.h: No such file or directory
> > In file included from ../Caption.h:37,
> > /usr/include/X11/Core.h:58: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
> or
> > ‘__attribute__’ before ‘WidgetClass’
> > what is wrong?
> > Mauro.
- fedora core 7 medm (was >> Re: MEDM compile - update :) Mauro Giacchini
- Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Heinrich du Toit
Re: genSub Tim Mooney
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
<2007>
2025
2026
fedora core 7 medm (was >> Re: MEDM compile - update :) Bertrand H.J. Biritz
<2007>
2025
2026
