1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC crashes with segmentation fault
To: "EPICS tech-talk" <[email protected]>
Date: Wed, 17 Oct 2007 11:09:19 -0700
I have a soft IOC which I evolved from myExample template.  It uses a suport module which is built from asyn devGpib template.  Initially, the only device IO done in the application was via asynRecords, all other records were of "Soft Channel" or <nil> type.  The application worked fine.
Today I added the following record:
record( stringin, "$(P)IDN"){
  field( DESC, "To keep the connection alive")
#  field( DTYP, "ks3988")
#  field( SCAN, "5 second")
#  field( INP,  "#L$(L) A0, @0")
To the devxxxx.db file and
device( stringin, GPIB_IO, devSiKS3988, "ks3988")
To the devxxxx.dbd file and
#define DSET_SI     devSiKS3988
static char sform[]="%39[^\r\n]";
static struct gpibCmd gpibCmds[]={
  {&DSET_SI,GPIBREAD,IB_Q_LOW,"*IDN?",sform,0,128,NULL,0,0,NULL,NULL,NULL},
To the devxxxx.c file.  The module compiles ok and the application compiles and links ok too.  With the line field( DTYP, "ks3988") commented out the application does not crash.  As soon as I uncomment the line and remake everything, the application crashes with Segmentation fault.  Here is what I see with gdb:
#!../../bin/linux-x86/ksTest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocksTest")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-8")
epicsEnvSet(GENSUB,"/afs/slac/g/esa/ilc/epics/modules/genSub/1-6")
epicsEnvSet(KS3988,"/afs/slac/g/esa/ilc/epics/modules/ks3988")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest
dbLoadDatabase("dbd/ksTest.dbd")
ksTest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
## Load record instances
dbLoadRecords( "db/dbExample1.db","P=KS:")
dbLoadRecords( "db/devKS3988.db","P=KS:,Q=AIO,W=AWRT,L=0,A=12")
dbLoadRecords( "db/asynIO.db","P=KS:,R=AIO,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
dbLoadRecords( "db/asynWrt.db","P=KS:,R=AWRT,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest/iocBoot/iocksTest
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Oct  2 2007
Segmentation fault (core dumped)
zms@esaux1 $ gdb ../../bin/linux-x86/ksTest core.14360
GNU gdb Red Hat Linux (6.3.0.0-1.143.el4rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "i386-redhat-linux-gnu"...Using host libthread_db lib
rary "/lib/tls/libthread_db.so.1".
Core was generated by `../../bin/linux-x86/ksTest st.cmd'.
Program terminated with signal 11, Segmentation fault.
Reading symbols from /afs/slac.stanford.edu/g/esa/ilc/epics/modules/ks3988/lib/l
inux-x86/libdevKS3988.so...done.
.... Omitted many lines here
#0  0x003cb393 in initRecord (precord=0x9759168, plink=0x97592e4)
    at ../../asyn/devGpib/devSupportGpib.c:230
230         if (pgpibCmd->dset != (gDset *) precord->dset) {
(gdb) bt
#1  0x003c98f6 in devGpib_initSi (psi=0x9759168)
    at ../../asyn/devGpib/devCommonGpib.c:941
#2  0x0073f488 in init_record (pstringin=0x9759168, pass=1)
    at ../stringinRecord.c:122
#3  0x0051c717 in iocInit () at ../iocInit.c:352
#4  0x009875be in iocInitCallFunc (args=0x96fa158) at ../dbAccessRegister.c:69
#5  0x009895d1 in iocshBody (pathname=0xbff715b9 "st.cmd", commandLine=0x0)
    at ../iocsh.cpp:743
#6  0x0804af62 in main (argc=2, argv=0x698ad30) at ../ksTestMain.cpp:17
Current language:  auto; currently c
(gdb)
I am working with EPICS R3.14.9 and asyn 4-8.
Any idea what I am doing wrong?
Thanks in advance,
Zen
Prev: Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Noboru Yamamoto
Next: Re: Display array of number in edm John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Display array of number in edm John Sinclair
Next: Visibility settings in EDM Dave Reid
