1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calculating status with invalid/non-existant inputs
To: Andrew Starritt <[email protected]>
Cc: [email protected]
Date: Tue, 23 Oct 2007 10:30:25 -0500
Andrew,
Use a calcout record. It has the field INAV, which holds the connection state of the
INPA link; and similar fields for other links.
Andrew Starritt wrote:
Hi all, To enable/disable some functionality, I sometimes do something like:
# Evaluates to 1 (true) if all condtions good otherwise 0 (false)
record (calc, "GOOD_TO_GO") {
   field (INPA, "PV1")
   field (INPB, "PV2")
   field (CALC, "(A=1)&&(B>=25):?1:0")
But what if PV1 or PV2 are invalid/undefined. Next I tried:
   field (INPA, "PV1")
   field (INPB, "PV2")
   field (INPC, "PV1.SEVR")
   field (INPD, "PV2.SEVR")
   # Note: INVALID_ALARM state value is 3.
   field (CALC, "(C#3)&&(D#3)&&(A=1)&&(B>=25):?1:0")
This works fine of PV1 and PV2 hosted on the same IOC as GOOD_TO_GO, but if
hosted on another IOC which is currently not available, the calc record is itself invalid.
3rd attemp.
record (ai, PV1_ALIAS") {
   field (INP, "PV1")
   field (INPA, "PV1_ALIAS")
   field (INPB, "PV2")
   field (INPC, "PV1_ALIAS.SEVR")
This helps. Even if the IOC hosting PV1 is down, PV1_ALIAS still exists
(albeit in an invalid state) and GOOD_TO_GO can evaluate successfully.
But if the IOC hosting PV1 is up and running, then PV1_ALIAS is not invalid
even when PV1 itself is invalid. I suppose I could create an alias process
varaible for PV1.SEVR as well, but that seems to be getting very messy.
   field (INP, "PV1")
record (ai, PV1_SEVR_ALIAS") {
   field (INP, "PV1.SEVR")
   field (INPB, "PV2")
   field (INPE, "PV1_SEVR_ALIAS")
   field (INPF, "PV1_SEVR_ALIAS.SEVR")
   field (CALC, "(C#3)&&(D#3)&&(E#3)&&(F#3)&&(A=1)&&(B>=25):?1:0")
Is there a simpler more elagant way do do this?
Regards Andrew Starritt _______________________________________ Senior Systems Engineer - Software Specialist Australian Synchrotron Project 800 Blackburn Road, Clayton, Victoria 3168 Tel: +61 3 8540 4164 Fax: +61 3 8540 4200
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
Calculating status with invalid/non-existant inputs Andrew Starritt
Prev: New release of Ipac Andrew Johnson
Next: Re: New release of Ipac/Asyn Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Calculating status with invalid/non-existant inputs Andrew Starritt
Next: Re: Calculating status with invalid/non-existant inputs Emmanuel Mayssat
