1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Calculating status with invalid/non-existant inputs
To: <[email protected]>
Date: Tue, 23 Oct 2007 12:47:43 +1000
Title: Calculating status with invalid/non-existant inputs
Hi all,
  To enable/disable some functionality, I sometimes do something like:
# Evaluates to 1 (true) if all condtions good otherwise 0 (false)
record (calc, "GOOD_TO_GO") {
   field (INPA, "PV1")
   field (INPB, "PV2")
   field (CALC, "(A=1)&&(B>=25):?1:0")
But what if PV1 or PV2 are invalid/undefined. Next I tried:
   field (INPA, "PV1")
   field (INPB, "PV2")
   field (INPC, "PV1.SEVR")
   field (INPD, "PV2.SEVR")
   # Note: INVALID_ALARM state value is 3.
   field (CALC, "(C#3)&&(D#3)&&(A=1)&&(B>=25):?1:0")
This works fine of PV1 and PV2 hosted on the same IOC as GOOD_TO_GO, but if
hosted on another IOC which is currently not available, the calc record is itself invalid.
3rd attemp.
record (ai, PV1_ALIAS") {
   field (INP, "PV1")
   field (INPA, "PV1_ALIAS")
   field (INPB, "PV2")
   field (INPC, "PV1_ALIAS.SEVR")
This helps. Even if the IOC hosting PV1 is down, PV1_ALIAS still exists
(albeit in an invalid state) and GOOD_TO_GO can evaluate successfully.
But if the IOC hosting PV1 is up and running, then PV1_ALIAS is not invalid
even when PV1 itself is invalid. I suppose I could create an alias process
varaible for PV1.SEVR as well, but that seems to be getting very messy.
   field (INP, "PV1")
record (ai, PV1_SEVR_ALIAS") {
   field (INP, "PV1.SEVR")
   field (INPB, "PV2")
   field (INPE, "PV1_SEVR_ALIAS")
   field (INPF, "PV1_SEVR_ALIAS.SEVR")
   field (CALC, "(C#3)&&(D#3)&&(E#3)&&(F#3)&&(A=1)&&(B>=25):?1:0")
Is there a simpler more elagant way do do this?
Regards
Andrew Starritt
_______________________________________
Senior Systems Engineer - Software Specialist
Australian Synchrotron Project
800 Blackburn Road, Clayton, Victoria 3168
Tel: +61 3 8540 4164
Fax: +61 3 8540 4200
Re: Calculating status with invalid/non-existant inputs Tim Mooney
Re: Calculating status with invalid/non-existant inputs Emmanuel Mayssat
Prev: New release of asyn and other modules Mark Rivers
Next: RE: Initial Value Andrew Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Calculating status with invalid/non-existant inputs Tim Mooney
