1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: another question on custom record stuff
To: [email protected]
Date: Fri, 26 Oct 2007 12:28:00 +0200
On Thursday 25 October 2007 16:58, Jeff Hill wrote:
> > Now the problem is that if I change the limit field then well.
> > MEDM just doesn't know about it.
> > So how do I get that part to run again?
> > Or is this another one of those impossible things :(
> Unfortunately, it's not currently possible for MEDM, or any other EPICS
> client, to subscribe for updates to be sent when there are changes in the
> limits. Therefore, most clients fetch the limits when they connect and
> assume that they don't change after that. Perhaps that might explain
> EDM's behavior.
> Note that MEDM will update its limits if its forced to reconnect.
My usual work around for this is to add a related-display-button to the
display which re-opens the same display. Obviously, this is a solution only
if the limits change in response to a user request, so it might not
applicable in your (the OPs) situation.
It would help if display clients allowed the user to chose dedicated
independent PVs (e.g. myRecord.HOPR) for display limits, falling back to
the CA provided limits if no dedicated PV has been configured.
Cheers
Ben
another question on custom record stuff Heinrich du Toit
RE: another question on custom record stuff Jeff Hill
Prev: Re: Automated logbook Matthias Clausen
Next: Motor support for PI E-621 Leicester, PJ (Pete)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: another question on custom record stuff Jeff Hill
Next: Epicstcl Eric Berryman
