1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GpibBoardDriverConfig not found
To: zhangdemin99 <[email protected]>
Date: Tue, 30 Oct 2007 13:08:54 +0100
Hi
Did you set LINUX_GPIB=YES in configure/RELEASE file when compiling asynDriver?
Regards
Gasper
zhangdemin99 wrote:
Dear all,
I haved built asyn4-8,linux-gpib-3.2.09 on my linux system. when I run the application for a GPIB device, there are some problems:
#!../../bin/linux-x86/PSM6003
##You may have to change PSM6003 to something else
##everywhere it appears in this file
<envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocPSM6003")
epicsEnvSet(TOP,"/home/zhm/software/gpib/psm6003")
epicsEnvSet(PSM6003,"/home/zhm/software/gpib/module/psm6003")
epicsEnvSet(ASYN,"/home/zhm/software/gpib/asyn")
epicsEnvSet(EPICS_BASE,"/home/zhm/software/gpib/base-3.14.9")
cd /home/zhm/software/gpib/psm6003
##Register all support components
dbLoadDatabase("dbd/PSM6003.dbd",0,0)
PSM6003_register Record Device Driver(pdbbase)
cd /home/zhm/software/gpib/asyn
##Load record instances
dbLoadRecords("db/asynRecord.db","P=PSM6003,R=Test,PORT=L0,ADDR=1,
IMAX=0,OMAX=0")
GpibBoardDriverConfig("L0",1,0,3,0)
st.cmd -- Line 17 --Command GpibBoardDriverConfig not found
cd /home/zhm/software/gpib/psm6003/iocBoot/iocPSM6003
iocInit()
Starting iocInit
##EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$
##EPICS Base built Oct 29 2007
2007/10/30 14:10:11.084 PSM6003Test:Connect error,status=3,asynManager:
connectDevice port L0 not found
iocInit:All initialization complete
##Start any sequence programs
#set sncxxx ,"user=zhmHost"
The CA server's beacon address list was empty after initialization?
epics>
any help or suggestions will be most welcome. Many thanks in advance.
demin zhang
LOGO æçåæåçåïåååèèäåé <http://popme.163.com/link/003515_0929_938.html>
åæååèçåèèåçåèå <http://popme.163.com/link/003515_0929_938.html>
GpibBoardDriverConfig not found zhangdemin99
Prev: GpibBoardDriverConfig not found zhangdemin99
Next: Re: combining values into graph? nda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: GpibBoardDriverConfig not found zhangdemin99
