1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: alh not handling log files correctly
To: [email protected]
Date: Tue, 30 Oct 2007 10:27:23 -0700
I've downloaded an built alh1_2_23 for Red Hat Enterprise Linux.
There are several problems related to viewing / changing the alarm log file. It actually crashes if I attempt to specify a new alarm log file:
Setup -> New Alarm Log File Name
crconlnx1.als.lbl.gov% ./alh.sh &
[1] 32688
crconlnx1.als.lbl.gov% no XML!
*** glibc detected *** free(): invalid next size (fast): 0x0839e748 ***
./alh.sh: line 10: 32689 Aborted alh -f /home/als/alsoper/alh -l /home/als/alsoper/alh/logs -global -m 0 -L -T als.alhConfig
The View->Current Alarm History shows a blank window even though there are active alarms.
The View->Alarm Log File Window also seems to be missing items. Again, there is a PV in major alarm that I would expect to see in the log file.
Is the 'no XML!' message important?
Chris Timossi
ALS/LBNL
Re: alh not handling log files correctly Janet Anderson
Prev: PV Gateway Problem Greg Lawson
Next: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: alh not handling log files correctly Janet Anderson
