1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alh not handling log files correctly
To: Chris Timossi <[email protected]>, TECHTALK <[email protected]>
Date: Tue, 30 Oct 2007 15:15:22 -0500
If I remember correctly, the alarm log and the current alarm history display
new alarm events (changes in alarm fields STAT and SEVR) as they happen.
Existing alarms are not logged when the alarm handler starts up because they
are not new alarm events.
The -T command line option from DESY creates alarm log files with special
dated names which are automatically switched at midnight. This option must
conflict with the runtime log file name change option.
An -xml command line option was added to alh by SNS.  If this flag exists
alh will use  XML-ish format for log files and will print "XML!" to stdout.
If it is not present, alh prints "no XML!" .
Janet
Chris Timossi wrote:
I've downloaded an built alh1_2_23 for Red Hat Enterprise Linux.
There are several problems related to viewing / changing the alarm log file. It actually crashes if I attempt to specify a new alarm log file:
Setup -> New Alarm Log File Name
crconlnx1.als.lbl.gov% ./alh.sh &
[1] 32688
crconlnx1.als.lbl.gov% no XML!
*** glibc detected *** free(): invalid next size (fast): 0x0839e748 ***
./alh.sh: line 10: 32689 Aborted alh -f /home/als/alsoper/alh -l /home/als/alsoper/alh/logs -global -m 0 -L -T als.alhConfig
The View->Current Alarm History shows a blank window even though there are active alarms.
The View->Alarm Log File Window also seems to be missing items. Again, there is a PV in major alarm that I would expect to see in the log file.
Is the 'no XML!' message important?
Chris Timossi
ALS/LBNL
Re: alh not handling log files correctly Chris Timossi
Prev: edd 1-11-0gz seg fault Kevin Tsubota
Next: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: alh not handling log files correctly Chris Timossi
Next: Re: alh not handling log files correctly Chris Timossi
