1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Raw converter and un/signed integrer
To: [email protected]
Date: Tue, 30 Oct 2007 16:53:00 -0700
All,
I actually see a strange behavior when I use the Raw Converter.
So far, I have been using StreamDevice in SynApps-5_2.
So now, I would like to reinstall the latest and greatest of
StreamDevice, a.k.a StreamDevice-2-3
Is there an install file hidden somewhere? I couldn't find it!
Apparently the tar.gz archive needs to be installed in epics-base, to be
able to find the configure directory. But there again, it doesn't fully
compile (iocshCmd linking error)... I am probably doing something wrong.
Where are the install instructions for StreamDevice?
Thank you,
E
On Tue, 2007-10-30 at 11:10 -0700, Emmanuel Mayssat wrote:
> Hello all,
> I am using stream and a 16 bit word to convert to an unsigned integer (0
> to 64xxx). The unsigned integer is coded on 2 characters.
> So I use the raw converter and particularly %2.2r
> But with that converter then the integer is signed (as mentioned in the
> doc). So I can read values between 0 to 32767 and -32768 to -1.
> Is there a way to use unsigned integer with the raw converter or do I
> have to write my own converter?
> Looking at the RawConverter.cc code, I am afraid that I will have to
> write my own...
> Emmanuel
Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Re: Stream Raw converter and un/signed integrer Dirk Zimoch
Prev: Re: alh not handling log files correctly Janet Anderson
Next: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Stream Raw converter and un/signed integrer Emmanuel Mayssat
