After looking in the code...
StreamDevice builds against 3.14.8.2+ otherwise iocshCmd is not defined
in iocsh.h (an include file in base).
But to my dismay RawConverter.cc has not been modified.
Let's see if I still get the strange behavior with that converter which
I noticed earlier.
(it seems that when using Raw for out and then in, the input/value
buffer is not fully cleared. As a result I read chars which appears in
the out string but whioch are never sent. More investigation is required
though).
I untarred StreamDevice in the stream/<version> directory of
synApps-5_2. There it compiles correctly.
Cheers,
E
On Tue, 2007-10-30 at 16:53 -0700, Emmanuel Mayssat wrote:
> All,
> I actually see a strange behavior when I use the Raw Converter.
> So far, I have been using StreamDevice in SynApps-5_2.
> So now, I would like to reinstall the latest and greatest of
> StreamDevice, a.k.a StreamDevice-2-3
> Is there an install file hidden somewhere? I couldn't find it!
> Apparently the tar.gz archive needs to be installed in epics-base, to be
> able to find the configure directory. But there again, it doesn't fully
> compile (iocshCmd linking error)... I am probably doing something wrong.
> Where are the install instructions for StreamDevice?
> Thank you,
> E
> On Tue, 2007-10-30 at 11:10 -0700, Emmanuel Mayssat wrote:
> > Hello all,
> > I am using stream and a 16 bit word to convert to an unsigned integer (0
> > to 64xxx). The unsigned integer is coded on 2 characters.
> > So I use the raw converter and particularly %2.2r
> > But with that converter then the integer is signed (as mentioned in the
> > doc). So I can read values between 0 to 32767 and -32768 to -1.
> > Is there a way to use unsigned integer with the raw converter or do I
> > have to write my own converter?
> > Looking at the RawConverter.cc code, I am afraid that I will have to
> > write my own...
> > Emmanuel
- Stream Raw converter and un/signed integrer Emmanuel Mayssat
- Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Re: Stream Raw converter and un/signed integrer Dirk Zimoch
<2007>
2025
2026
<2007>
2025
2026
