Hi Emmanuel,
It should be sufficient to pass the value through a calc record that does "A&65535".
I will probably add a flag to do unsigned conversion.
Dirk
Emmanuel Mayssat wrote:
Hello all,
I am using stream and a 16 bit word to convert to an unsigned integer (0
to 64xxx). The unsigned integer is coded on 2 characters.
So I use the raw converter and particularly %2.2r
But with that converter then the integer is signed (as mentioned in the
doc). So I can read values between 0 to 32767 and -32768 to -1.
Is there a way to use unsigned integer with the raw converter or do I
have to write my own converter?
Looking at the RawConverter.cc code, I am afraid that I will have to
write my own...
Emmanuel
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
- Stream Raw converter and un/signed integrer Emmanuel Mayssat
Re: Stream Raw converter and un/signed integrer Dirk Zimoch
<2007>
2025
2026
<2007>
2025
2026
