1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about iocConsole
To: "Allison, Stephanie" <[email protected]>
Date: Fri, 02 Nov 2007 20:10:31 +0100
Hello Stephanie,
note that Conserver is one layer above: It does logging and user/connection management for an arbitrary number of serial-type connections, so its main purpose is to unify access and logging for our soft and VME IOCs.
On the lower level, we use different types of terminal servers (console servers) to access VME based IOCs and the screen utility for soft IOCs. We're not doing much different things under the hood.
We don't particularily notice IOCs freezing because of screen scrolling, but we are annoyed by the vt100 commands that the screen client sends up to the Conserver - which Conserver puts into the log files and which just don't look nice.
So - replacing screen with something more appropriate would be very interesting for us, too.
We would still use and recommend Conserver as the integration layer on top, that makes accessing any soft or VME IOC as easy as typing
console <iocname>
on a machine that has the console program (Conserver client) available.
Ralph
Allison, Stephanie wrote:
Hi Marco,
I see this failure when the soft ioc failed to start. There are other system-related reasons.
Currently, the LCLS group at SLAC is changing to no longer start soft IOCs using the SLAC version of iocConsole and instead will use something called procServ - Ernest can give details.  Apparently, the soft IOC can freeze while somebody is paging up and down inside of screen - I've not reproduced it and debugged it though.   I also see that Ralph Lange uses something called conServer which looks interesting:
http://epics.aps.anl.gov/epics/wiki/index.php/How_to_Set_Up_Console_Access_and_Logging_for_VME_and_Soft_IOCs
Sorry I cannot be more help,
Stephanie Allison
question about iocConsole marco_hair
RE: question about iocConsole Allison, Stephanie
Prev: Re: lexical analyzer for .db? Ralph Lange
Next: Re: lexical analyzer for .db? Rodney R. Porter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: question about iocConsole Allison, Stephanie
Next: RE: question about iocConsole Ernest L. Williams Jr.
