Yes, The GPIB instrument is set to address 8, so I think that 8 in the asynTraceMask is correct.
Zen
-----Original Message-----
Sent: Monday, November 05, 2007 10:38 AM
To: Szalata, Zenon M.; Dirk Zimoch
Cc: EPICS tech-talk
Subject: RE: Stream device
Dirk wrote:
> I tried to do some debugging with the asynTrace facility and found
that the problem
> disappears as soon as I call asynSetTraceMask, even with a 0 mask!
That is because the asynSetTraceMask causes a call to
asynCommon->connect. I had suggested this earlier to Zen. However, I
see that you used an asyn "address" of 8, while I was suggesting 0.
Zen, are you sure you tried adding the asynSetTraceMask with the subaddress that your @init device is actually using?
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Monday, November 05, 2007 12:11 PM
> To: Dirk Zimoch
> Cc: EPICS tech-talk
> Hi Dirk,
> Unfortunately this does not solve my problem. I am using epics
> R3.14.9 and asyn 4-9. This is the output I get with my simple test
> soft IOC:
> zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
> #!../../bin/linux-x86/atest < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iocagwfg")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
> epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
> epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
> cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
> dbLoadDatabase("dbd/atest.dbd",0,0)
> atest_registerRecordDeviceDriver(pdbbase)
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> #asynSetTraceMask( "L0",0,255)
> asynSetTraceMask( "L0",8,0)
> dbLoadRecords("db/atest.db","P=AG:")
> cd
> /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
> iocInit()
> Starting iocInit
> ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base
> built Oct 2 2007
> 2007/11/05 09:51:13.140 AG:WFreq: asynError in write: L0 port is not
> connected
> 2007/11/05 09:51:13.141 AG:WFreq: @init handler failed
> 2007/11/05 09:51:13.141 AG:WFreq: Record initialization failed Bad
> init_rec return value PV: AG:WFreq ao: init_record
> iocInit: All initialization complete
> epics> 2007/11/05 09:51:23.143 AG:RFreq: asynError in write:
> L0 port is not conn
> ected
> exit
> zms@esaux1 $
> Here are my atest.db and atest.proto files:
> record( ai,"$(P)RFreq"){
> field( DESC, "read frequency")
> field( DTYP, "stream")
> field( SCAN, "10 second")
> field( PREC, "2")
> field( EGU, "Hz")
> field( INP, "@atest.proto rFreq L0 8") } record( ao,"$(P)WFreq"){
> field( DESC, "write frequency")
> field( SCAN, "Passive")
> field( PREC, "2")
> field( EGU, "Hz")
> field( OUT, "@atest.proto wFreq L0 8") }
> # file: atest.proto
> Terminator=LF;
> rFreq{ out "FREQ?"; in "%f";}
> wFreq{ out "FREQ %f"; @init{ rFreq;}}
> Here is the tail end of constructed atest.dbd file:
> device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
> device(asyn,INST_IO,asynRecordDevice,"asynRecordDevice")
> driver(stream)
> driver(drvAsyn)
> registrar(asSub)
> registrar(streamRegistrar)
> registrar(asynRegister)
> registrar(asynInterposeFlushRegister)
> registrar(asynInterposeEosRegister)
> registrar(vxi11RegisterCommands)
> registrar(drvAsynIPPortRegisterCommands)
> registrar(drvAsynSerialPortRegisterCommands)
> variable(asCaDebug,int)
> variable(dbRecordsOnceOnly,int)
> variable(dbBptNotMonotonic,int)
> variable(streamDebug,int)
> And finally, her is atestApp/src/Makefile:
> TOP=../..
> include $(TOP)/configure/CONFIG
> PROD_IOC = atest
> DBD += atest.dbd
> atest_DBD += base.dbd
> atest_DBD += stream.dbd
> atest_DBD += asyn.dbd
> atest_DBD += drvVxi11.dbd
> atest_DBD += atestSup.dbd
> # <name>_registerRecordDeviceDriver.cpp will be created from
> <name>.dbd atest_SRCS += atest_registerRecordDeviceDriver.cpp
> atest_SRCS_DEFAULT += atestMain.cpp
> atest_SRCS_vxWorks += -nil-
> #The following adds support from base/src/vxWorks atest_OBJS_vxWorks
> += $(EPICS_BASE_BIN)/vxComLibrary
> #add a definition for each support application used by this
> application atest_LIBS += stream atest_LIBS += asyn
> atest_LIBS += $(EPICS_BASE_IOC_LIBS)
> include $(TOP)/configure/RULES
> Are you using earlier versions of Epics or asyn? If you are using the
> same version of these two packages, am I missing something in my
> Makefile or some other files?
> Thanks for helping,
> Zen
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Monday, November 05, 2007 5:59 AM
> Subject: Re: Stream device
> Hello Zen,
> I tested @init handlers with several devices today. I found that TCP
> ports as well as serial ports work as expected. The problem only
> occurs with vxi11 ports.
> However, I got different error messages:
> 2007/11/05 13:57:32.057 gpib0,8 vxiCreateDeviceLink RPC error
> : RPC: Timed out
> 2007/11/05 13:57:32.058 L0 vxiCreateDevLink failed for addr 8
> 2007/11/05 13:57:32.058 asynManager::asynConnectCallback, port L0
> error calling
> asynCommon->connect
> 2007/11/05 13:57:36.067 L0 vxi11 clientCall errno 0 clnt_stat
> 5 L0 vxiBusStatus RPC error : RPC: Timed out
> 2007/11/05 13:57:36.067 L0 asynGpib:srqPoll srqStatus error timeout
> 2007/11/05 13:57:40.077 L0 vxi11 clientIoCall errno 0 clnt_stat 5
> 2007/11/05 13:57:40.077 DZ:cmd: asynError in write: L0 RPC failed
> 2007/11/05 13:57:40.078 DZ:cmd: @init handler failed
> 2007/11/05 13:57:40.078 DZ:cmd: Record initialization failed
> StreamDevice error messages start with "asynError in write:
> L0 RPC failed". All above is drvVxi11 or asynManager.
> that the problem disappears as soon as I call asynSetTraceMask, even
> with a 0 mask!
> Thus try this in your startup script:
> asynSetTraceMask ("L0",8,0)
> However, I still have not the slightest idea what goes wrong in the
> vxi11 driver.
> I Hope this helps.
> Dirk
- RE: Stream device Szalata, Zenon M.
- RE: Stream device Mark Rivers
Tornado 2.2.2 bug Ron Sluiter
<2007>
2025
2026
<2007>
2025
2026
