For anyone upgrading to Tornado 2.2.2 (VxWorks 5.5.2); be aware that there is a problem with target shell redirection. Here is how I described it to Wind River Systems (WRS) in the TSR; WRS tells me that since there is a workaround (i.e., use ld 0,0,"filename"), this will notIf the loader (ld) is invoked from the startup script using the redirected input format (e.g., ld < test.o) rather than the file format (e.g., ld 0,0,"test.o"), then no further redirected input from the startup script will work. get fixed until the next cumulative patch release (Tornado 2.2.3?). Ron
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
