On a related note, if you use the mv2700 and/or mv5100 BSPs and upgrade
your installation to Tornado 2.2.2 (vxWorks 5.5.2), you will have to do
some work fixing up the Level 2 cache support code to get these
particular boards to work properly. You can turn off the L2 cache as a
short-term workaround on the mv5100, but this solution doesn't
completely fix the mv2700.
I can provide more information about what has to be done on request.
Thus Ron and I recommend that you only install the patch to upgrade to
Tornado 2.2.2 if you really need it, either for bug fixes of for the
NFSv3 support.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Tornado 2.2.2 bug Ron Sluiter
RE: cmlog ? (still not working) Heinrich du Toit
<2007>
2025
2026
Qt edm code John Sinclair
<2007>
2025
2026
