1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on Mac OS X 10.5
To: Eric Norum <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 06 Nov 2007 17:36:41 +0900
Hi Eric,
Eric Norum wrote:
> Just adding the prototype is likely to just postpone the problem till
> link time (undefined symbol finite).  I think that it would be better to
> use the standard routine instead:
> 1) Find all references to finite and change them to isfinite.
> 2) For systems which provide finite() rather than isfinite(), add a
> macro to <os>/epicsMath.h defining the latter as the former.
I agree. Actually, I have replaced all references to finit() in
epicsCalcTest.cpp to that to isfinite() and found it is compiled without
any error.
So your epicsMath.h for os/Darwin should work for Darwin platform.
Noboru
> On Nov 4, 2007, at 5:46 PM, Noboru Yamamoto wrote:
>> Hi,
>> On MacOSX 10.5, finite() is declared
>> extern int finite ( double );                   /* Legacy API: please
>> use C99 isfinite() instead. */
>> but not
>> extern "C" int finite(double);
>> This seems causing the error shown by Biritz-san.
>> 1) replace call to finite with call to isfinite.
>> or
>> 2) add
>> in somewhere in epicsCalcTest.cpp.
>> eliminates the error message.
>> Bertrand H.J. Biritz wrote:
>>> Dear Tech-Talk,
>>> so I am one of those Mac fanboys (at least when it comes to the OS) who
>>> installed OS X 10.5 (Leopard) as soon as it came out.
>>> Naturally EPICS will not compile on it - would have been surprised if it
>>> had. I get the following error message:
>>> ../epicsCalcTest.cpp: In function 'double doCalc(const char*)':
>>> ../epicsCalcTest.cpp:31: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp: In function 'void testCalc(const char*, double)':
>>> ../epicsCalcTest.cpp:51: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp:55: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp: In function 'int main(int, char**)':
>>> ../epicsCalcTest.cpp:170: error: 'finite' was not declared in this scope
>>> make[3]: *** [epicsCalcTest.o] Error 1
>>> make[2]: *** [install.darwin-ppc] Error 2
>>> make[1]: *** [libCom/test.install] Error 2
>>> make: *** [src.install] Error 2
>>> Did I miss something in the installation instructions?
>>> This is with base-3.14.9 on a PPC.
>>> Thanks,
>>> Bertrand
>> my environment:
>> Mac OSX10.5 running on MacBook(1st generation).
>> Xcode 3.0
>> EPICS R3.14.9 base
>> Regards,
>> Noboru
>> <noboru.yamamoto.vcf>
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: EPICS on Mac OS X 10.5 Andrew Johnson
EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
Re: EPICS on Mac OS X 10.5 Noboru Yamamoto
Re: EPICS on Mac OS X 10.5 Eric Norum
Prev: RE: cmlog ? (still not working) Heinrich du Toit
Next: Qt edm code John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS on Mac OS X 10.5 Eric Norum
Next: Re: EPICS on Mac OS X 10.5 Andrew Johnson
